Tow hook help please
All aspects of safety with 4wds from proper mounting of tow hooks to recovery situations.
Batfastard
Dr. Love Glove
Post by Batfastard »
Dose anyone have any pics of front tow hooks on a ln106 hilux.this lux got standard hilux alloy bars that mount on bolt on under side of chassis.i had a quick look underneath this arvo.need to fit soon as .of to godely next tuseday.looks ike i need to make some brackets up to bolt to chassis .then bolt hooks on them.or is there an easyer way
nstacey
Re: Tow hook help please
Post by nstacey »
You should have some captive nuts that are in front of the spring hanger. The two that are there (on each side) are the correct spacing for the rated aftermarket hooks. You might find that your bullbar bolts to the same captive nuts though.
85 Hilux single cab
02 Grand Vitara
Smurf
Post by Smurf »
50mm Right angle bolted to the bolts on underside of chassis, and hooks bolted to that, if you want your hooks right way up?
rangimotors
Post by rangimotors »
nstacey wrote:You should have some captive nuts that are in front of the spring hanger. The two that are there (on each side) are the correct spacing for the rated aftermarket hooks. You might find that your bullbar bolts to the same captive nuts though.
just don't use the bolts that come with the hook as they are standard thread and the factory holes are metric fine thread.
There are 3 holes on each side you can use so its nice to use all 3 on each side (total of 6 ) with a frame between them and a hook mounted in the middle to spead the load.
Batfastard
Dr. Love Glove
Yes bullbars bolt on there.not that keen to mount off captive nuts.
Smurf
Post by Smurf »
Did you get your hooks sorted?
Batfastard
Dr. Love Glove
Smurf wrote:Did you get your hooks sorted?
All sorted.the work good ,wraped my strop around the local power pole give it a good pull .both snatch and steady pull.... :mrgreen:
Smurf
Post by Smurf »
Cool. You shouldn't get stuck on the Godley trip now you have a hook .. LOL
Smurf wrote:Cool. You shouldn't get stuck on the Godley trip now you have a hook .. LOL
shit the poor buggar's going to need about 10 hooks if last years trips anything to go on Image :lol:
Batfastard
Dr. Love Glove
Or not ten hooks its taken me six months to fit two.....lol :D
Return to “4wd Safety”
