ideas for fixing windows on landcruiser??
waka
Post by waka »
just wondering if any one knows how or who to fix windows on 1991 landcruiser 80 series. the windows only go down half way sometimes and really slow go up or down. dOES any one know how where and how much to fix this issue.
tomsoffroad
Flopsie
Re: ideas for fixing windows on landcruiser??
Post by tomsoffroad »
Maybe it needs to be pulled apart, cleaned and lubed?
4WDbits
Post by 4WDbits »
Pull the weather seal off the door and give it a good clean, muck builds up under them creating friction on the window. The runners the glass sits in also gets muck and damp in it and expands creating extra friction. Sometimes a bit of dry lube will do the job. Can be time consuming doing all the cleaning, but cheaper than burning out a motor.
petefj40
Ms Daisy
Post by petefj40 »
Mine do the same mate. I've cleaned them, lubed them. They are better but they'll never be as good as replacing the rubber seals. They harden with age. wjw (Bill) had the rubbers imported at half the price Toyota wanted for them last year. I'll do the same once I get In touch with him and let you know how I get on.
badnuz
Post by badnuz »
petefj40
Ms Daisy
Post by petefj40 »
Cheers Euan.
Apprantly the importer in Japan got washed way in that tsunami. But I heard they are back up and running again in a new location. I'll get in touch with Bill next week.
oldblue
Post by oldblue »
Could it be that the window switch needs to be dismanteled and cleaned, they do carbon up.
waka
Post by waka »
Thanks guys I will try these suggestions. I'm not expecting them to be perfect just wanting them to open more freely so in the summer time dog has air in the back. :P
wjw
Post by wjw »
petefj40 wrote:
Cheers Euan.
Sent the email this morning, should get a reply tonight.
Who knew Prados could fly?
pressy
Post by pressy »
wjw wrote:
petefj40 wrote:
Cheers Euan.
Hi bill X 2 Please?
Munks1
Post by Munks1 »
x3 please.
Had mine 'fixed' so many times i could have paid for a new 80.
The last wanker who 'fixed' them threw my tinted window away, replaced with a second hand window, chucked out my seals and didnt replace them. :evil:
So yes please for a set of window rubbers and seals.
waka
Post by waka »
yes please im very keen to get a price for all 4 need all of them working for summer so can get air in for dog in the back and to chuck the misses out if she talks to much. :shock:
Flannel
Post by Flannel »
id be keen on all 4 runners too.
I did manage to vastly improve the rears by taking them out with the window in situ, and giving them a good hot clean & dry & then slide them back in.
wjw
Post by wjw »
4,420 Yen 68141-60010 Run, Front Door Glass, LH
4,420 Yen 68151-60010 Run, Front Door Glass, RH
3,670 Yen 68142-60010 changed to 68142-60011 Run, Rear Door Glass, RH
3,670 Yen 68152-60010 changed to 68152-60011 Run, Rear Door Glass LH
7,500 Yen Shipping to Christchurch
Y23,680 which is about $370NZD.
Who in Christchurch wants some? anyone outside I'll need to get freight price direct to you.
waka
Post by waka »
yes thanks. is that $370 for all 4 ? seals and rubbers? and landed here in chch?
wjw
Post by wjw »
waka wrote:yes thanks. is that $370 for all 4 ? seals and rubbers? and landed here in chch?
$370 is for all 4 they are a single piece for each window, the only charge on top of that will be the paypal fees, which I wont know until I do the transaction. Last time that was around $30.
petefj40
Ms Daisy
Post by petefj40 »
Thanks heaps for your help there Bill. I got your txt. I'll be in touch. At the moment, my problem is the motor is about to come out of the 80 this week and I'm preparing myself for that cost right now. :shock:
waka
Post by waka »
yes thank you very much for your help i am taking the truck in to make sure this is the problem first. If it is i am very keen to get it sorted and will get in touch with you soon.
willferris
Mr Mumbles
Post by willferris »
Will buy all 4 s well
waka
Post by waka »
wow im glad this thread has helped other people than myself. A true compliment to this site and how well it works.
Flannel
Post by Flannel »
will also buy 4.
waka
Post by waka »
Yes thanks count me in. Just took it to a mate and said the rubber seals have harden up and can't be saved. Yes you can clean them and lubricate the seals but this is an on going process that is never ending. Also this may cause the electric windows motor to blow which then your In the SH... So may as well bite the bullet and solve the problem once and for all and enjoy the windows working well for the summer
pressy
Post by pressy »
when you thinking of doing the order bill?
keen on a couple for my front doors passenger door 68141‑60020, will get the drivers code
wjw
Post by wjw »
pressy wrote:when you thinking of doing the order bill?
When my credit card isn't full :-)
waka
Post by waka »
I'm happy to pay or make a
Decent deposit if this helps? Maybe we could all do this to make it easier.
waka
Post by waka »
Sorry meant pay/ deposit now before you order not after.
cameroncrusoe
Post by cameroncrusoe »
Yes me to, for four. Am happy to pay deposit of say $200 if needed or what ever it takes to make it happen. Will have to sort out your bank account details and a address to send it to. mine are stuffed. 96 80 series. Cheers
ClassicCruiserSpares
Im keen for a set of 4 also, happy to pay at the time of order.
DaveM
Post by DaveM »
Just out of interest, is this rubber seal the "bailey channel seal"?
