installing a eton trutrac into mates hilux and was hoping to take it out for a play tomrow but unfortanaly we cant find the pinion touqe for the colapsable spacer, and the backlash clerance for pinion to crownwheel.
PLEASE we need your help
hilux Diff tauqes ASAP
Re: hilux Diff tauqes ASAP
lloked up the link and couldnt find the tourqe for the pinion tauqe, were needing the tauqe for the input flange nut, cause due to the colapsable washer they have we dont want to over do it or under do it, there is the whole do it up till the clearance has gone but we realy want to be sure
There is no specific torque for the pinion, you crush the spacer untill you get the correct preload on the pinion bearings.
If you have installed the trutrac into an existing diff you shouldn't have to remove the pinion?..or have you put in all new bearings?
If you have replaced the bearings you will need to check the pinion depth as well.
looks like someone reads as well as they write.
14 in/lb (1.6 Nm) start torque with new bearing.
site has a heap of examples you can follow, complete with pictures
