Fitting 15" rims to a GQ
For all Nissan related topics
T-mo
Post by T-mo »
Hi,
I've heard of people running 15" rims on GQ Safari and Patrols. While tinkering in the shed I tried my flatmates 15" x 8" (0 offset) rims onto my GQ but they wouldn't clear the from calipers on the front. Rear was fine and bolted up.
Was wondering if anyone had any experience with fitting 15s to GQs. I was thinking that f I got a bigger -ve offset they may clear but I'm unsure.
Any advice will be appreciated.
Tomo
1991 Nissan Safari AD SWB TD42 - 33x12.5 BFG KMs, 2" lift + more coming.
"Never let a nerd loose with a torque wrench."
Swamped
Re: Fitting 15" rims to a GQ
Post by Swamped »
15in steelies fit my gq fine
charo249
Post by charo249 »
Will need to have a negative offset to fit. For 15x8 rims on a Patrol (or any other japanese 4wd with a beam axle for that matter) I suggest you try either -19 or -22 offset rims
passengerpete
Post by passengerpete »
i got 15x8 -12 on mine. but wanted to run 0 good thing i did not go out and buy some yet. how close was it from fitting ? what type of wheel was it ?
T-mo
Post by T-mo »
Standard 15" 0 offset white steel rim. I believe he brought it off 4WDbits but am unsure. Common as rims.
Tomo
DEATH_INC
Post by DEATH_INC »
If it has factory 16's I'm pretty sure the 15's won't go. Same as some Landcruiser, 'cept it's the rear that won't work.
