Steel rims - best place in chch?
JRDO
Post by JRDO »
Want to get a set of steel rims for the rugger, would be quite keen to get them in chch so I can check they fit first.
Have seen spacers need a cert but does anyone know if you can run a 25mm offset rim without needing a cert?
DEATH_INC
Re: Steel rims - best place in chch?
Post by DEATH_INC »
Yep, that's the crazy thing...a 25mm adaptor/spacer requires a cert, yet you can bolt on a 44mm offset wheels without one.....
keithal
Post by keithal »
DEATH_INC wrote:Yep, that's the crazy thing...a 25mm adaptor/spacer requires a cert, yet you can bolt on a 44mm offset wheels without one.....
by adding a spacer you are adding another point where the rim/wheel combination could shear off where as the rim is still mounting to the original hub face so only 1 shear point
Big
Post by Big »
DEATH_INC wrote: 27mm adaptor/spacer requires a cert, yet you can bolt on a 44mm offset wheels without one.....
27 mm maximum..
Return to “Tyres”
