Loosing breaks
For all Suzuki related topics
tnr
Loosing breaks
Post by tnr »
Lately I have been loosing breaks mainly offroad however it happened in a car park the other day. I have noticed it happen when revving it and turnin.. Few pumps and there back..... Any ideas why?
ice4x4
Re: Loosing breaks
Post by ice4x4 »
When was the last time the fluid was changed? Could be boiling if it has a lot of moisture in there..
1988 Range Rover Classic
2010 Discovery 4 HSE 5.0 V8
niblik
Re: Loosing breaks
Post by niblik »
What's the vehicle that they're in, that you're losing brakes in?
NJV6
Re: Loosing breaks
Post by NJV6 »
I'd say you need some Brake fluid, break fluid is not very effective, in fact I don't think you can buy it any more.
CLUMZ1
Re: Loosing breaks
Post by CLUMZ1 »
Well, break fluid won't fix anything, only break it more!
zukmeista
Re: Loosing breaks
Post by zukmeista »
Seeing as no-one else has been helpful, I spent a bit of time looking for a potential solution, check this out.http://www.auszookers.com/forum/viewtopic.php?f=5&t=31475&hilit=brake+issue :wink:
Re: Loosing breaks
tnr wrote:Lately I have been loosing breaks mainly offroad however it happened in a car park the other day. I have noticed it happen when revving it and turnin.. Few pumps and there back..... Any ideas why?
you need to provide some more info about whats happening to get some reasonable answers mate, is the pedal dropping to the floor or are you just losing clamping ability on the callipers/drums, is it only an intermittant problem, what sort of vehicle and are the brakes disc, drum or a mixture, booster or no booster, are you losing brake fluid, have you checked you've got vaccum
tnr
Re: Loosing breaks
Post by tnr »
ice4x4 wrote:When was the last time the fluid was changed? Could be boiling if it has a lot of moisture in there..
I bled them when I installed lift kit so maybe 200km ago
tnr
Re: Loosing breaks
Post by tnr »
zukmeista wrote:Seeing as no-one else has been helpful, I spent a bit of time looking for a potential solution, check this out.http://www.auszookers.com/forum/viewtopic.php?f=5&t=31475&hilit=brake+issue :wink:
Think you could be on the mark here as I remember it only started when I lift it, as pulled off the link...
You lot think too much!
Too much lock + lifted vit = caliper hits spring and knocks the piston back a bit so you have to pump it back in place
Adjust your steering stops a bit so it doesnt hit, or just left foot pump the pedal as you roll into tight spots like I do
tnr
Re: Loosing breaks
Post by tnr »
Yea pedal dropping to the floor yea intermittent booster disk front drum rear vitara
suzookyman
Re: Loosing breaks
Post by suzookyman »
do you have disk/disk or disk/drum or drum/drum? what truck do you have?
Al
tnr
Re: Loosing breaks
Post by tnr »
suzookyman wrote:do you have disk/disk or disk/drum or drum/drum? what truck do you have?
Al
Disk drum
Return to “Suzuki”
