70 series cruiser reduction gears where to buy from
brakes-shocks-lockers-etc
ToyRover
Post by ToyRover »
looking for reduction gears for a 70 series cruiser with a auto only ones in nz is like $3500 just to buy the gears and bearing let a long put them in any help would be good
kbushnz
Re: 70 series cruiser reduction gears where to buy from
Post by kbushnz »
Marks 4WD is aussie are good....
http://www.marks4wd.com/products/gearma ... -gears.htm
There is a reseller in the USA...which sometimes depending on the dollar can be cheaper. But then shipping stuffs it up...
sig
Jeep Jeep
Post by sig »
there is another option ,70 series prados use the same type of transfer but have a lower low range 2.3 as against 1.96 for cruisers.I haven,t done a changeover yet but i am going to try on my 40 at some stage ( when my prado is finished).I bought one of these transfers for 200 bucks.Mine is off an auto which is slightly different but i am hopefull it will work .Drive shaft pattern is different but i hope the flanges will change over
