my heater valve is broken and need to sort out. the valve never worked from the dash any way so just want to bypass it. any idea which hose can be blanked off?? i no its not the one going through the firewall cause thats where the water goes when the heater is turned on its the other's im confused about. one goes back to the engine and the other under the vehicle to the center console heater.
i think this is in the right place
heater valve override
- mikeyt1689
- Bush Crasher
Re: heater valve override
All you need to do is locate where the heater hoses connect to the motor and join them together, problem solved.
