how do i tell what model i have
benorange
Post by benorange »
i just brought a 93 surf with a 1kz-te in it and but has no badges. its wide body cloth interior auto 1kz-te lsd
1justin
Re: how do i tell what model i have
Post by 1justin »
probably have something on the vin plate or the other plate beside that.
northland_pajero
Post by northland_pajero »
Try carjam.co.nz put the rego in an it might have the model number as part of the chassis number, I know my hilux has.
tweake
Post by tweake »
plate in the engine bay will have it.
Crash bandicoot
Post by Crash bandicoot »
KZN130 or KLN130.(if originally a diesel)
scramble under the rear axle on the drivers side and let us know if the pinion housing has 3 or 4 horizontal fins on it.
most likely a ssr-G or ssr-X,
the late 80's models came with the crap 3vz-fe v6 that popped head gaskets like they were going out of fashion
benorange
Post by benorange »
i know it a kzn130 i wanted to know if it a ssr-x or g and what is the difrance
Crash bandicoot
trim levels inside the cab and some mechanical options such as four spider LSD with 4.5 ratios...thats why i said stick your head under the drivers side rear axle and tell us how many fins are on the pinion housing and i'll tell you what spec it is.
the ssr G was the top of the range there were X and V or just ssr where differing trim levels such as chrome grill or plastic light types, wide flares, A/C, even if you had a clock on the dash board. crap like that.
tweake
Post by tweake »
theres also a ton of options available. eg different sized tires and diff ratios. model number does not mean a whole lot.
