Hi all,
On my bj40 it has new lifted springs in the back and old flat ones in the front, what i would like to know is if i can put the diff under the front springs and if any mods need to be made for it to work and if it needs to be cert. i know it wont add any flex but would be better till i do get new ones. Would this work or should i just leave it?
Reece
Diff under springs
Re: Diff under springs
Scobby12 wrote:Hi all,
Reece
Didn't barbie drive a jeep??
Scobby12 wrote: i know it wont add any flex but would be better till i do get new ones.
its not quite that simple mate, if you SOA it you'll probably lift the front close to 8 inches, 50mm for the thickness of the spring pack and probably 150mm for the diameter of the axle housing and the hight of the spring perch. That much lift will give you a shit front driveshaft angle and it'll probably flog out U/Js pretty quick and have a bit of driveline vibration, usually you cut the swivel balls and rotate the axle housing to get a better driveshaft pinion angle and reweld the swivel balls back on to keep the caster angle the same, you'll probably have to do a high steer conversion to get the draglink up higher so it dosent foul on the springs.
so in short its not a quick easy fix untill you get some new front springs
Fakey wrote:Scobby12 wrote:Hi all,
Reece
are you serious? Try searching fj40 soa (spring over axle)
Well im not an expert on these thing hence why im asking..
Sadam_Husain wrote:Scobby12 wrote: i know it wont add any flex but would be better till i do get new ones.
Awesome thanks mate didnt relise it lifted it that high haha will just leave it and get some new Springs
