zukmeista wrote:I think the V6 Escudo's have bigger brake calipers which means you can't fit 15" rims.
churchill wrote:^ Correct. I fitted 245/75/16 (30.5") on mine without a body lift. Had to do lots of guard work and space out the bump stops to control the rubbing.
Chairmen wrote:Thanks Churchill, after hearing your input i think ill do a 2 or 3 inch body lift and 265/70R15 tyres. How did you find your 4x4 low gearing on you V6 with 30.5" tyres???![]()
churchill wrote:Chairmen wrote:Thanks Churchill, after hearing your input i think ill do a 2 or 3 inch body lift and 265/70R15 tyres. How did you find your 4x4 low gearing on you V6 with 30.5" tyres???![]()
I wasn't the greatest with the 4.88 ratio diffs but came back to almost normal with a change to 5.12 diffs.
Low range is to high in these vehicles. Standard they are around 1.8-1.9:1, I would like to try a kit that drops it down to 2.5-3.0:1. There are 4.14:1 kits but I feel they are a little too low.
