Alternative 4 a magnetic sump plug
De-Ranged
Post by De-Ranged »
If your draining the oil from engine, trans, diffs or what ever and you want to see if there has been any nasty wear and the drain plugs arn't magnetic use a magnetic wand avaliable from most tool shops for around $7 just run it around the inside of the oil container and then gently stir it in some petrol
Something simple
Cheers Reece
Cheers Reece
De Ranged Engineering
027 541 8794
