Landcrusier Longfield 30 Spline Superset Axles CV's for sal
Moderator: Vendors
Hi,
New thread as other one was getting a bit long.
Old one is here http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=64&t=21142
FJ60's $1200 plus freight in NZ. OR With Longs Hub Gears to go in your AISIN hubs, $1400 all up plus freight in NZ.
FJ60's with long spline for cable locker $1200 plus freight in NZ. OR With Longs Hub Gears to go in your AISIN hubs, $1400 all up plus freight in NZ.
ONLY ONE FJ60 LONG SPLINE LEFT
FJ40 with long spline for cable locker $1200 plus freight in NZ. OR With Longs Hub Gears to go in your AISIN hubs, $1400 all up plus freight in NZ.
Note that the FJ40 ones also fit the 70 series with the 9" diff head
Also got drive flanges for $300/pair instead of using FWH's. This is a stronger setup as the drive flanges also have pins to take the load as well.
Also note for the Longfield warranty on the CV outer spline you need to be running either the Hub Gears or Drive Flanges.
Post is around $40 depending on where you are.
PM me if interested.
Thanks
Tim
Thanks
Tim
Re: Landcrusier Longfield 30 Spline Superset Axles CV's for
Bump,
See first post
PM me if interested
Thank you
Tim
See first post
PM me if interested
Thank you
Tim
Bump,
See first post
PM me if interested
Thank you
Tim
See first post
PM me if interested
Thank you
Tim
Bump,
See first post
PM me if interested
Thank you
Tim
See first post
PM me if interested
Thank you
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
Now only $1200
See first post
PM me if interested
Tim
Now only $1200
See first post
PM me if interested
Tim
Bump.
Now only $1200
See first post
PM me if interested
Tim
Now only $1200
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
