od light flashing kzn130
benorange
Post by benorange »
been driving new truck for 3 weeks now. now the od light started flashing. i did find a wee switch when i was cleaning it out conected to speedo that i turned off for a bit to see what it did could this be conected
northland_pajero
Re: od light flashing kzn130
Post by northland_pajero »
If they are anything like a Pajero I would say yes the two are related. A Pajero auto will not go into od unless the engine has reached a certain temp and it is going over a certain speed (80km/h I think)
tallsam66
Post by tallsam66 »
You have an issue with the trans .
Put it into diagnostics mode & read the flash code.
benorange
Post by benorange »
still goes into od with switch off
how do i do the code thing on these? done on other cars that you just join to plugs is this the same, if so what colour plug i looking for.
evolution02
Post by evolution02 »
Having no speedo working will cause your O/D light to flash
Does it work fine with the speedo working?
benorange
Post by benorange »
cool seems to be just the switch causin it as when you turn it back on it goes away. just seamed odd that i could drive it round with it off and not have light on then then it would ramdomly come on.
jonossiksilvia
Post by jonossiksilvia »
