Forget the godwinch...........
Re: Forget the godwinch...........
Love to know what pulling that, only looks like 2 usual electric motors on a custom winch, but it has way to much gfrunt and speed
According to Youtube comments section: "It is based on a warn low mount. Runs twin motors at 24v. It is was built by Russel Mason from Rockhampton."
Ive seen them on a couple of other sites, they run a modded low mount with up to three 6hp warn xp 12v motors running 24volts through them..........
Damm cool though
Damm cool though
- crazyclark31
faarrrkkk me thats impressive.
That is some serious winching speed
Does make me wonder how it would handle our deep mud though
crazyclark31 wrote:faarrrkkk me thats impressive.![]()
spot on with the mud comment...all that extra resistance etc etc....
having said that we have a modified high mount warn to run of a seperate 24v system to mount in the patrol as the back up winch if the PTO gives up the ghost
i have run 24v throught a 12v low mount winch, and yes they crank along well
how long it would last ??
I have always wondered if you could use something like the 12v to 24v switching system from the starting system of an 80 series and selectively choose when to run 24v through your 12v winch.
I like the cam belt linking the motors!!!!
Pretty common winch set up over here. Used to work with a guy who has a twin motor 24v high mount winch built by the same guy in his mwb patrol. They don't run 24v thru 12v motors. They run up to 4 motors thru custom made gear set up. They have a winch dedicated 24v alternator an separate batteries. They are very cool but cost more than 10k to set up
Didn't barbie drive a jeep??
Friend of mine built a twin motor setup like that. Twin alternators twin batteries, think he had his setup 12v tho, one battery for each motor. So it could run like a 2spd, 1 or both motors going. It pulled bloody impressive up hills etc, but for recovery from mud etc it was so fast the plasma would just snap like a rubber band lol
- Gnarly Dude
- Bush Crasher
See this guys running 4 6hp motors. PPOOOOWWWEEERRR!!!!!
http://www.youtube.com/watch?v=6-OPlXBZ ... ure=relmfu
