i had a small search, but figured some of you might make this quicker for me
im over in aussie and trying to track down the steel cased diff for ya vitaras, can someone post the model i should be looking for and pics info etc, anything to help me, help you basically
Vitara steel diffs
Vitara steel diffs
Re: Vitara steel diffs
Are you trying to track one down in Australia or in New Zealand? Or either?
Where is the vehicle the diff would go in?
This place has them from time to time:
http://www.auszookers.com/forum/viewforum.php?f=7
- Chairmen
I think you want to get them out of the 98 too 01 V6 Grand Vitara.
However there not cheep tho. Unless you come by a wrecker/seller who don't know there value.
Are you trying to track down in AUZY or NZ ?
gotflex is a mate of mine, he now lives in ozzy and is trying to find a load of steelie diffs for us.
i think he works at a 4wd wreckers......
- Chairmen
Oh sweet what a good dude
... I hope he strick's gold with his search
What ratio do ya need? Or do you put your crown and pinion from the alloy into the steel?
Any ratio mate, 5.12 would be nice, but any ratio will be fine
only certain engine/trans combos had steel front diffs
TD31 Manual = 4.3
TD32 Manual = 4.3
TD62 Manual = 4.3
TD82 Manual = 4.1
TD83 Manual = 4.1
TD31 Manual = 4.3
TD32 Manual = 4.3
TD62 Manual = 4.3
TD82 Manual = 4.1
TD83 Manual = 4.1
