Hilux recovery hook mounting?
DaveM
Post by DaveM »
Hi all,
a mate has a 96ish hilux and needs to mount a couple of hooks on for an upcoming coast trip.
Can he just drill a couple of holes in the bullbar (steel) and mount them off there? It will mean they are in line with the chassis which may help?
How about the back? He was going to use a shackle on the towbar, but can only fit a 3 1/4t one on there.
Any tips/pics are appreciated.
Dave
monaro427
Post by monaro427 »
i just got myself another touge and drilled two holes for the mounting of the recovery hook thats for the rear not sure on front already have them mounted,
Mattman
Post by Mattman »
Usually there are mounting points on the front chassis rails for hooks however these might be used if there is a nudge bar.
On mine the nudge bar has a 3mm plate and my hooks mount underneath that with the bolts securing the nudge bar and hooks to the predrilled and tapped chassis mounts.
Off the side of the towbar or off the tounge is a good place in the rear.
Matt.
