Disco 1 HD rear springs
Disco Gofer
Post by Disco Gofer »
Hi, I'm looking for a pair of rear heavy duty springs for my TDi. Like all Discos it sits down when I have my bush truck on the back and hate blinding drivers at night despite balancing the trailer out as best as possible. Is it cheap enough to have some made or off the shelf ?
Bernhard
Dirtydog
Re: Disco 1 HD rear springs
Post by Dirtydog »
Maybe those poly airbags would work?
wouldnt lift the back of the car, and they arnt too expensive, and you can choose the spring rate.
xj
Post by xj »
lilpig lilpig... I believe someone could do with your advise!!!
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Disco Gofer
Dirtydog wrote:Maybe those poly airbags would work?
Will look into that.mi want the height the same just harder. I only use the Disco for towing every 3/4 week end so not worried about a hard ride when not towing.
Jono51
Post by Jono51 »
Disco Gofer wrote:Hi, I'm looking for a pair of rear heavy duty springs for my TDi. Like all Discos it sits down when I have my bush truck on the back and hate blinding drivers at night despite balancing the trailer out as best as possible. Is it cheap enough to have some made or off the shelf ?
Bernhard
cheap enough to get made in NZ, however best to do the fronts as well, as I find that they sag
I use Cobra
