Hi,
Need some help with a couple of questions to help with the preparation of doing an SAS on my Surf. Plus will be doing other mods, engine transplant, longer rear springs, rear disc's etc, will start a thread once I actually start doing something.
1. Are all solid axles from the 80's and 90's Surfs and Hilux's the same width. If not what are the differences.
2. I think I have seen somewhere a mod to increase the width by fitting IFS hubs, is this a feasible mod and what is involved. Will be fitting my Surf discs and calipers to the solid axle.
Thanks for any help.
Tim
Hilux Surf Front Solid Axle Questions
Surfs only has solid axles until early 86 but the NZ new single and double cabs went thru with solid axles until mid 1990's.
The only difference you'll have is the later axles have the vented rotors, although some real early axles had no truss on the housing.
For rear disk conversion - if you get an early solid rotor axle then you can use the front rotors with the Gallant rear calipers, or if you got vented then go Subaru.
The IFS front conversion is simple and will only cost you for some new bolts and the spacers.
Its all good
Its all good
RN46 and previous (up to 1984) had half-gusseted front axles (the gusset only goes from the pumpkin to the u-bolt on the long side
LN60 Surfs (1984-85) had solid axles the same as LN65 utes
LN65 onwards utes through till 1996 had fully gussetted housings (right out to the ball
LN106 onwards had vented rotors and larger calipers. (All had 4-pot calipers, just bigger pots on the 106-onwards ones).
You can bolt on the vented rotors onto the older axles, and bolt on the later calipers (found on LN61 IFS and 130-series IFS surfs as well)
The IFS hub adaption for more width requires some ifs hubs (obviously
), longer bolts, a new dust seal thats been trimmed down, and the spacer... pretty much a bolt-together mod for 3" more overall width.
WARNING: DON'T fit your surf rotors to the solid axle, they are a different offset and a smaller diameter. Buy new solid rotors for a 106 (also found on late 40-series cruisers and 60-series cruisers) and use the surf IFS calipers...
Hope that helps... take lots of pics
Steve
Steve
- hosehustler
Its my warning based on having researched the certification issue, and having had that setup in my truck some time back.
If the pads do not fully contact the surface of the rotors (and using the IFS rotors they can not possibly do so, you loose 5mm or so of pad contact off the outer edge) then they will not pass cert.
Why use the IFS ones when you can use the solid axle ones and have full contact?
Steve
Steve
Another option for the IFS hub swop is to redrill your disks so they bolt up to the IFS hub disk mounts then get 1.5mm machined off the new contact side of the brake caliper posts this will then bolt the caliper up on the outside of the swivel housing brake posts and line up nice en neat
and legal!!
IF your willing to wait a day or two I'll post a how to, I'm just about ready to put my front axle back together so I'll take some pics as I go
Cheers Reece
Cheers Reece
