rocky on roids
2roky
rocky on roids
Post by 2roky »
figured i should start a build thread seeing as my project is finally starting to take shape.
the base for the project was a 1995 daihatsu rocky (f300)
the plan is/was to strip the chassis down and put hilux axles under it with either coils or coilovers on it and a toyota v6 and auto out of a surf. and as per any other serious build it will get a winch and and other bar work etc.
1st step was to strip it down to the chassis and cut all the ifs crap of.
it sat idle for the better part of 6months while i tried to figure out the suspension system
after playing around trying to devise a way to mount a set of landrover discovery radius arms i come to the conclusion it would be easier to build a 3link+panhard system.
link 900mm long
toyota surf trailing arm bushes
plate cut for mounts
chassis mount folded up
mounts tacked to chassis
i still have to build the chassis mount for the top link and the diff mounts. also i now need to decide whether or not to go coils or coil overs. if i go coil overs it will be a few months before i can afford them if i go coils i can do it sooner but will have to go through all the hassle of building mounts for them. not sure what would be better of the two choices.
DA RAM
Re: rocky on roids
Post by DA RAM »
good start 8)
coilovers if you can wait ? easier to mount , work harder and take up less room ,
ive had a rocky on 33's good little trucks ,all the best with ya the build 8)
GO HARD OR GO HOME !
2015 JK Rubicon
jervisad
Re: rocky on roids
Post by jervisad »
this is gonna be cool man :mrgreen: good luck with the build
2roky
Re: rocky on roids
Post by 2roky »
cheers guys yeh im leaning towards coilovers for the ease of fitting them and also the fact that they work better. its going to be a slowish build i think
suzolla
Re: rocky on roids
Post by suzolla »
Nice work with the folded up mounts.
Just a thought with your bushes, the lurathan generally do not flex as well and the rubber ones, have you checked how much they will twist when the axle articulates. Plus it has been said that off road the rubber ones last longer as well. I guess time will tell.
Keep up the good work.
Tim
2roky
Re: rocky on roids
Post by 2roky »
cheers,
i discovered dont try and design mounts hung over. did the mounts to the diff the other morning and completely over looked the fact that the top of the diff is curved and not square...... :| that will learn me.
i havent checked articulation as of yet as im still to mount the diff up. that will be done next.
im using the nolathane brand bushes which i heard somewhere were meant to be softer and harder wearing than the rubber ones? i could be wrong and its not too late to change the plans yet either as to which bush i run thankfully
niblik
Re: rocky on roids
Post by niblik »
nolathane,in my dealings, is stiffer dude..
Dirtydog
Re: rocky on roids
Post by Dirtydog »
nalathane is good in situations like sports cars etc, really makes a difference in normal cars too, but the nolathane bushes in my truck wore down reall fast, i had to replace control arm bushes after about 6 months.
slide
Re: rocky on roids
Post by slide »
2roky wrote:im using the nolathane brand bushes which i heard somewhere were meant to be softer and harder wearing than the rubber ones?
I would change that to harder, and faster wearing than rubber.
Excellent in sports cars where there's minimal angular movement of suspension arms, and you don't want the softness of rubber to change alignment under load.
But less than ideal in 4x4's...
jervisad
Re: rocky on roids
Post by jervisad »
yeah i found this to that when i put the rubber ones in they have lasted ages and the ride was a tad smoother and in a sj the ride is pretty shocking :lol:
