2h turbo?
hiace007
2h turbo?
Post by hiace007 »
have just pickd up an recond 2h am going to slap in to my fj45 and wanting to turbo it any one got any gud info on wat turbo they used and how they went thanx
land bruiser
Re: 2h turbo?
Post by land bruiser »
Hi there, I turboed my 60 serries 2H. Got the turbo from a 60serries with the 12ht engine. Used the manifold and ct26 turbo from 12ht, bolted straight on and i got the oil feed from the oil sender unit, Oil sender is on the drivers side under the intake mainfold. Allso removed sump and put in the oil drain. I had to make my ducting from air box to turbo and turbo to engine alltough this wasnt hard just a pain better if you can sourse the factory ones. Im running 10.5 with no problems at all
I HAVE 60 SERRIES PARTS FOR SALE
land bruiser
Re: 2h turbo?
hiace007
Re: 2h turbo?
Post by hiace007 »
wat do you think a Toyota1hdt turbo would be like when you doing a hundred k on the motor way is turbo on boost if so wat psi and wat egt you geting on step hills with load
land bruiser
Re: 2h turbo?
Sorry im unfimilar with a 1hdt. All i can tell you is its not that hard to turbo a 2h and that ive had no problems at all with my truck. It doesnt use any more diesel and im not holding up all the trafic anymore. The main reason i used the 12ht and ct26 turbo was that it all just bolts on. I will admit i had a few problems at first. As in the turbo not getting oil but $125 for a rebuild kit and its sweet as now.
suzolla
Re: 2h turbo?
Post by suzolla »
1hdt also uses a CT26
Tim
