terreno fuel tank remove how
For all Nissan related topics
philip121
Post by philip121 »
now i want to remove or just drop the fuel tank so i can fisoline up under there so will unbolting all the bolts drop the tank so i can spray i dont want if i can help take the tank out.... fisholined everywhere but not obove tank chassis looks great
Paulballz
Re: terreno fuel tank remove how
Post by Paulballz »
4 bolts up front by memory an 4 in rear..If body lifted go though right rear wheeel arch an undo clamps on filler hose an small hose beside it otherwise you take wheel off an get right in there...two ways of doing fuel lines a) lift boot carpet and there in inspection hatch with 4x bolts which you can take fuel line clamps off... b) simply lower tank half way an remove them an fuel gauge plug... either way easy joballow 15 - 30 mins depending on tools used (fuel tank holding bolts are most likely seized so powerbar them off an antiseize when re installing). Obviously less fuel = less swearing
