1991 terreno sprrdo cable remove and replace how
For all Nissan related topics
philip121
Post by philip121 »
the speedo cable in broken that inside bit that fits into the tail thing underfloor
now i unscrewed that end so its off how do i ud plug the other end is it all under the dash where it unplugs the small cable is brroke not the tube thing it spins in
lax2wlg
Re: 1991 terreno sprrdo cable remove and replace how
Post by lax2wlg »
The other end of the cable goes directly to the speedo console, so you need to remove the plastic trim piece surrounding the speedo, then remove the console and pull the whole unit back to gain access.
I think after 93 they went to electric speedo/speed sensor.
philip121
Post by philip121 »
ok undone dash consol pulled cable off speedo how does the cable pull out as its got big conections on both ends there is a small metal screwed plate the cable goes though on the firewall that also stops the removal of cable
philip121
Post by philip121 »
its out will take in get the inside cable many thanks that thing on the fire wall had me but you undo it pull it pop shes off
lax2wlg
Post by lax2wlg »
Good to hear you got the cable out pretty easily, yeah the Japanese are very thoughtful with these things!
