Hey guys,
Im having issues with my battery's going flat nothing has been left on and still there going flat but its started since i stopped using the crappy 24v to 13v inverter for the stereo and run the pos an neg from one battery straight to the head unit. now because its a 24v set up does this mean im draining the one battery to much ??
Battery problem
Re: Battery problem
yea mate, you cant draw off of one battery in a 24v set up.( unless you fit a even charger/charge equilizer) as you will cook both batteries, as one will end up being over chareged and one undercharged. if its just a stereo your need on 12v, i would just go buy a decent reducer
Re: Battery problem
skidmark wrote:yea mate, you cant draw off of one battery in a 24v set up.( unless you fit a even charger/charge equilizer) as you will cook both batteries, as one will end up being over chareged and one undercharged. if its just a stereo your need on 12v, i would just go buy a decent reducer
Awesome mate cheers! yea i had a feeling it might have caused it hopefully iv got to it in time new battery's are a rip off
Re: Battery problem
manatoa wrote:hopefully iv got to it in time new battery's are a rip off
24 volt systems NEED to have the same size/capacity, age and condition batteries hooked together. If it was me, pay the money, start afresh, problem solved. With a good voltage reducer hooked up properly so the memory circuit stays powered up, it will work the way it is supposed to.
Because you have used one of the batteries independently and it has gone flat a number of times they are no longer a "matched pair".
Just my 10c worth.
Re: Battery problem
sibainmud wrote:manatoa wrote:hopefully iv got to it in time new battery's are a rip off
Just my 10c worth.
Yea i no i should but changing truck tyres for a living doesn't pay as well as you would think haha but its on the wish list for sure !
Re: Battery problem
to get them balanced ( as best as their going to be) hook them together in parallel(out of the truck, positive to positive,negative to negative) and hook them up to a good charger and charge them up..
