new front brake pads in 1991 outo 2.7d brake pedal soft
For all Nissan related topics
philip121
Post by philip121 »
is that normal on these outos for the brakes pedel to feel soft how do i ajust this
BogBoy
Re: new front brake pads in 1991 outo 2.7d brake pedal soft
Post by BogBoy »
philip121 wrote:is that normal on these outos for the brakes pedel to feel soft how do i ajust this
The pedal feel will get better as the pads bed in properly
I had the same issue when I replaced my disks and pads
V8boss
Post by V8boss »
Did you machine or replace the discs? If not, the pads will be flexing when you push on the pedal, giving you that soft feel. Can be dangerous as pads can get damaged if the flex is too much.
philip121
Post by philip121 »
I see i just put new pads in the front did not machine disks as i drive i do notice a slight improvment i done abot 12 miles so far the brakes work just soft pedal at times thanks i should have know are there self ajusting brakes
philip121
Post by philip121 »
YES you were correct the brakes beded in and it passed a warrent
many thanks
