Any CHCH boys have a spare aircon controller unit. i have a little fualt with the clutch to start the a/c pump.
i have tested the clutch with a positive lead and it engages. next is to trace the cable backwards.
manual shows an A/C CUT Relay this will be my next check point.
Anyone knows were it hides.
Many thanks
Jono
VX Air Controller unit
Re: VX Air Controller unit
are u sure that is the problem,If your gas pressure gets low it wont cut in
yea just been reading that.
so ive just tryed jumping the clutch on with a battery and then see if there is any cold air
nope so i think i may have a little leak.
Owell i tryed, time to take truck into a A/C Company
If it turns out to be the control unit, I guess you mean the nice block in the dash? I have one that works but has two buttons missing.
Who knew Prados could fly?
yep ac has a saftey low pressure switch to protect your compressor if no gas.. chances are you got no gas..shouldnt be a major for someone to pressure test it to find out weather you got a leak...
cheers boys. Bill may i borrow ur spare unit just wont to make sure my unit is ok, yea its the big dash unit.
Sure, pickup from my work? Will be there till 2 tomorrow. Level 3, 6 Hazeldean road. Txt me if you do and I'll put in in the truck 021 241 7206
hey johno have you checked the gas level in the sight glass? maybe out gas.on the right handside beside the radator you will see a filter and a sight glass should see a white liquid in it and it will be pretty full.
