Parts for 2.8 turbo conversion + query
Sh0tgun
Post by Sh0tgun »
Anyone got any of these of a 2lte engine?
Looking at turboing my 2.8 3L :wink:
Am new to Auckland so don't really know where to find stuff.
1) CT20 Turbo
2) Exhaust Manifold
3) Dump Manifold Off The Turbo
4) Pressure Crossover Pipe with Rubber Couplings
5) Intake tube (low pressure side) with rocker cover vent tube.
6) 90 Degree Elbow Off Low Pressure Side of Turbo
Any help would be much appreciated
Smurf
Re: Looking for parts for 2.8 turbo conversion
Post by Smurf »
you also want the oil cooler plate and thermostat housing and the water lines from turbo to thermostat etc
Sh0tgun
Post by Sh0tgun »
Cheers will add them to the list
mumbls
Post by mumbls »
buy a surf with blowen head, swap all gear over, sell surf with blowen head an no turbo gear. profit.
drinking hatorgade
mumbls
Post by mumbls »
drinking hatorgade
Sh0tgun
Post by Sh0tgun »
Cheers for the link
Sh0tgun
Post by Sh0tgun »
Anyone else have anything lying around? Or know of someone that has a surf with a cracked head? The last guy i tried told me the parts where mine and then sold them off to someone else without telling me. :(
Smurf
Post by Smurf »
tweake
Post by tweake »
lucky you didn't get that one cause it won't fit a 2.8 hilux!
2.8SURF
Post by 2.8SURF »
All ive got lying around after a clean out is the steel pipe from the turbo to the inlet, crossover pipe with "D-TURBO" on it
Not being used but not really worth sending it to you as you can probably pick it up from the same place you get the turbo from.
gigidy gigidy gigidy goo
Sh0tgun
Post by Sh0tgun »
Thanks for the reply's
Quick question:
Is it worth using the oil cooler plate or just pluming into the alternator feed?
One advantage would be the change to the Z334 filter over the Z9, but is it worth the hassle?
Updated list
1) CT20 Turbo
2) Exhaust Manifold
5) Intake tube (low pressure side) with rocker cover vent tube if possible
7) Thermostat housing complete to where it bolts onto block with lines to turbo if possible
8 ) Oil Cooler Plate
Thanks
tweake
Re: Parts for 2.8 turbo conversion + query
Post by tweake »
the z334 filter is a dual filter. part of it filters very fine particles. however it tends to block up rather quickly.
i run a z9 filter but you need to watch oil pressure as it can block up quicker. but z9's are dirt cheap compared to z334.
the oil feed can be bent to one of the oil connections on the block next to the alternator feed. otherwise you can get new turbo oil fittings which take AN fittings and make your own oil lines.
Sh0tgun
Post by Sh0tgun »
The connection next to my banjo bolt for the alt has a oil pressure sender attached to it currently
tweake
Post by tweake »
Sh0tgun wrote:The connection next to my banjo bolt for the alt has a oil pressure sender attached to it currently
i think theres two or three locations. move pressure sensor to the rear location and the back of the block.
Sh0tgun
Post by Sh0tgun »
Manged to get everything except the oil cooler plate and the turbo itself.
However may forgo the oil cooler mod.
So really just looking for a CT20 turbo.
Thanks
