And yes, it does have Landrover's patented 'rust protection system' installed.
lilpigzuk wrote:on full compression that axle has to move to the left a good 30mm atleast? Thats a hell of a strain on the bushes/shackles
zukmeista wrote:lilpigzuk wrote:on full compression that axle has to move to the left a good 30mm atleast? Thats a hell of a strain on the bushes/shackles
Yes, that is why people reckon it's a good idea to chuck it, supposed to make them flex better and with open diffs it needs all it can get!![]()
Not sure whether the diffs have any relation to Dana diffs, the center is a similar style but the knuckles are the usual Jap setup with C.V.'s.
meatc wrote:Its there to remove the bump steer. If you take it out the diff wont move sideways as it moves up and down and with the crossover steering this will induce bump steer.
Same principal as the track rod thing on a leaf sprung lux, but this has crossowver steer, not a j arm
