Right been looking around cant find any info so ill bother you guys,
I wired my uhf radio in, now i assumed the Aerial needs to use both the internal copper core and the braided outer wires to the internal and external of the plug,
Now heres my issue when i do that i can park almost right next to my mate and get distortion and 3-4 car lengths away ends coverage,
But if i un plug the aerial i get better coverage and if i just use the center solid copper core i get better signal, but still only about a km or so
Any input is welcome
Cheers jordan
Radio/prs guru help wanted
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
(027 788 1046)
Re: Radio/prs guru help wanted
Trying to operate a radio without the antenna can damage the transmitter. What type of coaxial cable are you using. Typically the cable has pre installed ends. Can you put up some pictures of the setup.
Just a guess but i suspect you have a short between the screen & centre core.
What sort of aerial is it?
You really want a ground independant aerial.
Have a read of this.
http://www.gme.net.au/public/pdf/brochures/antennaslr.pdf
If you are willing to come over to mine I can have a look for you
Txt me for address etc.
Ph 0212078472
Ph 0212078472
kiwipete wrote:If you are willing to come over to mine I can have a look for you![]()
Do this.
Pete knows his stuff
IS this the same as CB where the cable length is critical too?
Pete was very helpful, found a short at the aerial end of the plug
He bumped his head soldered some wires and it was all go
Great meeting you pete thanks again!
(027 788 1046)
(027 788 1046)
My pleasure Jordan, glad we sorted it
Catch you on the trails sometime.
My bloody head hurts though.
gotta watch those flying crowbars.
Ph 0212078472
Ph 0212078472
