All in the title realy. Ive seached but not come up with anything. To get a front and rear set of 3" lifted flexi coils out of aussie is super pricey... Freight is $500NZ or so for a full set. The coils themselves are $700 AUS which is fine.
Can any one shead some light on how to get them into nz cheaper or an nz supplier?
Bit of backround if you like... The springs will be for a swb gq safari. Im only after a 3" lift so i wont need adj or lengthened panhards and also keep cog down. Will be running drop boxes. Currently on 33"s will go 35"s and guard trim as finances allow.
Thanks for any suggestions.
nz supplier of flexi coils?
shaun.paddy
- Bush Crasher
shaun.paddy
- Bush Crasher
Re: nz supplier of flexi coils?
Yep coil springs.... But flexi coils
. So they lift the truck 3" but perform as though your running a 6" lift flex wise, which allows a longer travel shock to be used. Made by suspension stuff and another company i cant recal (that i know of). Thanks any how.
Think sus. stuff in oz has (had?) Dobinson make them to his specs. Not sure if they are available except directly through him.
The leeway for bringing stuff into NZ from Aust is $700Aust, bringing them back with you shouldn't incurr any extra charges. If you have them sent over unaccompanied then you are liable for full gst and customs duty.
Try getting prices on this site. Suspension Stuff put me onto it when I was there last year, cheap freight....but it's unaccompanied once again.
https://www.ship2anywhere.com.au/quote/
shaun.paddy
- Bush Crasher
Thanks for that twodiffs. Looks like the cheapest freight will be $197 AUD. Also customs
would be after $200NZD. On the bright side brother inlaw is heading this way in a few weeks. May have to see if he can bring them over... Maybe as sporting goods ha
