diff lock
For all Nissan related topics
hallr
diff lock
Post by hallr »
Hi guys
I have just fitted a factory diff lock to to rear on nissan safari.When using it and turning right it clicks in and out.turning left ok.You can here it go in/out of gear when using switch on dash.It was a complete diff when fitted.diff head never been out.The diff has only dun 75 thousand ks.
Has any body got any ideas.
cheers Reg
Lchundy
Re: diff lock
Post by Lchundy »
My mates that have patrols had issues with the valve that activates them.
they put those mac valves in and there sweet.
Might be worth a look
tgaguy1
Re: diff lock
Post by tgaguy1 »
Sounds to me like you might have a problem with the preload on the wheel bearings. The Safari rear wheel bearings are shimmed under the outer axle flange. I can't recall the limits but if you get hold of a manual it is clear how to set it up.
Cheers.
Jase.
hallr
Re: diff lock
Post by hallr »
thanks 4 that cheers Reg
imsohi
Re: diff lock
Post by imsohi »
one of my mates had this problem the dog clutch in the diff was shagged had beveled the teath off mind you it had done 350 kms + hope this is not the case with yours.
albundy
Rolly Polly
Re: diff lock
Post by albundy »
imsohi wrote:one of my mates had this problem the dog clutch in the diff was shagged had beveled the teath off mind you it had done 350 kms + hope this is not the case with yours.
This will be the problem, mine was the same. A gearmaker can fix it pretty cheaply for you. I had mine done in CHCH, but I think he may have been levelled.
Al
surfer x2
Re: diff lock
Post by surfer x2 »
Mike Jones gears in chch has fixed one for me he is still around.
hallr
Re: diff lock
Post by hallr »
Thanks guys 4 the info. Will check them all out.
Cheers Reg
hallr
Re: diff lock
Post by hallr »
Thanks 4 the info on MacValves they work great luhundy. Cheers Reg
