Done a good search and need help with the following:
Basically i'm fitting up the winch and want to do it right the first time especially with the price of cable.
Everyone is suggesting using 70mm2 cable min and some are using the 95mm2 stuff.
trouble is i'm having a hard time finding the cable everyone is using. so far have only been able to find some 50mm2 cable from redpaths for $22+gst per meter and is total diameter of 15mm - see photos at end. so with this cable at 95mm2 would put the diameter at 29mm approx and the issue is this stuff is $39+gst per meter and is huge when trying to find space to run it and it looks alot bigger by looking at the pics of the orange stuff that people have been putting photos up of.
Rang Boc and apparently they dont have any stock of the orange stuff at there sockburn branch currently so cant go see it to see if its suitable - they said they can order it for me but 5meters of the stuff is alot of money if its the wrong stuff.
Can anyone please be able to measure the diameter of their cables the same way as i have in below picture that they have got from Boc so i can see the sizing of it? is this stuff really flexible? ie good for running sharp corners.
Pictures below:
Cheers guys
Ps dont shoot me if i used wrong search terms
Edit: Here is the mounting location for the solinold box. its 1m between that and winch. also you can see the 2 650cca batteries also
