engine options
2roky
engine options
Post by 2roky »
giday i just bourght a 87 surf thats got a f@#ked motor its running on 3 the guy i got it off thinks that its a blown head gasket but i think it could be a rooted piston or bore cause he was offroading with out a air filter so he sucked a lot of shite straight into the motor i was wondering what types of motors are out there that would fit straight in at a low cost. i'm going to be running 33's or bigger and cert isn't a problem as its not going on the road. any ideas would be great.
MATT4U
Post by MATT4U »
supra
2roky
Post by 2roky »
wots the cost of one of them?
NuTTa
Post by NuTTa »
got my motor out of a cressida for $50.00 see this post
http://www.offroadexpress.co.nz/modules ... pic&t=3458
and this site http://www.4wd.net.nz/suprasurf.htm
Brendon
MATT4U
Post by MATT4U »
I payed $100 for a doner supra, bellhousings will cost bout $300. you can get a 7m auto bellhousing and get an adapter for $150. you can use the standard engine mounts sometimes but your engine will sit on a funny angle.
Clint
Post by Clint »
Ya might want to look into a solid axle swap at the same time. IFS Surf diffs, 33"+ tyres & more hp are not a group that play well together :D
Clint
UZJ71 Landcruiser
KTM 640
hiriklux
Post by hiriklux »
2jz 8) 8) 8) 8) 8) a bit pricey but throws shit for miles
2roky
Post by 2roky »
dont have to worry about diffs beam axle model just needs a new motor this ones f@#Kd got a cressida lined up for it now though
