Toyota supercustom
Toyota supercustom
I have just purchased a Toyota super custom, but cant find a owners manual or workshop manual for it. If anyone has a copy I could borrow and photocopy or an electronic copy to email my it would be much appreciated... I need to replace the alternator but don't have a clue how to go about it..... And for those nitpickers it will soon be towing a bush truck... Thanks in advance Jonny
Re: Toyota supercustom
Tui anyone
Tui anyone
CLUMZ1 wrote:http://goo.gl/QvuEb should help with the info.
Should help you in general http://bit.ly/10vCQoJ
- skid
- Tyre Man
pickles wrote:CLUMZ1 wrote:http://goo.gl/QvuEb should help with the info.
quoted before it vanishes
I Have already had a look and spent a lot of time searching online without any luck..... Hence why I'm asking on here...
- evolution02
Alternator is bottom on drivers side so will have to remove the drivers seat and the large panel that the handbrake should be on. Once you have access to engine you take aircon belt off then unbolt aircon pump and move aside as much as hoses allow. You should now have easy access to alternator loosen tensioner, disconnect plug and battery wire then unbolt alternator
