could also be the arm on the steering box has moved (stripped shaft a little,or been moved before you bought it??) to a non-centred position, therefore giving you less turn one way, seen it before on a mitsi starion. If it is, it's an easy fix, remove the arm, figure out where the centre point in the box is, then reattach the arm...... easy peasy!!
