thermostat help!!
thermostat help!!
hi anyone please please guide me how to change thermostat on my mitsubishi pajero v6 3000cc 1993?? the engine temparature have not been sitting still lately. it was at the right running engine temparature after the engine is hot, but after 4/5 minutes the temperature will raise to half for 30 seconds and then back to normal. radiator has been clean properly (removed and clean) and also flushed last two month. replace with new thermostat after cleaning but then think it could be the thermostat that is faulty again now. dont want to go to the workshop again, so, just bought the thermostat and the gasket and want to learn how to fit in myself. please anyone?? thanksss
its easy on them
drain coolant
undo top hose to engine remove top hose
undo two bolts holding thermostat top housing on
remove top housing you may have to tap with soft hammer to break seal
when removed you will see thermostat remove thermostat and fit new one
before you fit top housing make sure all surfaces are clean if got no new gasket just seal with instant gasket make sure you dont get any on thermostate
bolt on top housing fit top hose back on and fill with water
leave running with rad cap off to get all air out of system for about ten mins
put rad cap on take for a run just to get warm let it cool down and then check coolant level again
hope this helps you
Kev
drain coolant
hope this helps you
Kev
