Never work underneath a car with only one form of support
All aspects of safety with 4wds from proper mounting of tow hooks to recovery situations.
Colinl
Post by Colinl »
http://www.stuff.co.nz/national/8780232 ... -car-named
I know i know.. that if you have all 4 wheel on ur 4wd you'll crawl out of it no probs(for the skinny ones) I do my oil changes on the ute without having to use a jack.
Just a reminder that siccsor jacks a limp as feck by themselves. Sad to think a set of $40 jack stands or even a block of firewood could have saved this mans life.
Bonus
Re: Never work underneath a car with only one form of suppor
Post by Bonus »
Such a waste, even when im using 2 axel stands I will still leave my big trolley jack in place as a backup
Dirtydog
Post by Dirtydog »
Bonus wrote:Such a waste, even when im using 2 axel stands I will still leave my big trolley jack in place as a backup
Same here, both for ease of getting them off and for safety.
even then im thinking of putting some bigger feet on the ones i have, they still look like they can fall over.
prado_boon
Post by prado_boon »
Thats tragic, and its a sad but harsh way to remember those saftey things. I know I cut corners sometimes!
That story doesn't 100% add up to me. If he could yell out to his flatmate then why didnt his flatmate jack the car up again ??? it would take 30 seconds max to rip the jack out and re-jack the car up ?
The story seems to indicate that the car wes left ontop of him until the fire brigade came? Maybe he panicked
Bonus
Post by Bonus »
prado_boon wrote:Thats tragic, and its a sad but harsh way to remember those saftey things. I know I cut corners sometimes!
Id say the jack failed and was unusable, or was stuck/crushed under the car
jonossiksilvia
Post by jonossiksilvia »
maybe jack was stuck too?
i also leave jack under with axle stands and if doing major work usually spear rims under tires
mudlva
Post by mudlva »
good keen man out doing a oil change at 10.30 at night. :shock:
just shows the importance of a couple of simple things like either ramps or axle stands to minimize that risk ah
tallsam66
Post by tallsam66 »
The drive is on a slight lean & car rolled forward a little & off the jack.I assume the jack was either bent & or stuck under car.
evolution02
Post by evolution02 »
I knew of this guy and the other silly thing is he used to be a mechanic so really should've known better.
Still beats me why anyone would be outside changing their oil at 10:30pm
yeti
Bruiser
Post by yeti »
yep don't take much for a brain fade.....still getting over my jeep rolling over me out on the river earlier this year.......
v8 tj...luvs the gas......
vvilly
Post by vvilly »
yeti wrote:yep don't take much for a brain fade.....still getting over my jeep rolling over me out on the river earlier this year.......
I was thinking bout that when i seen this lol
How are the ribs
tltourer
Post by tltourer »
A guy I knew did this, yanking on a bolt under the car, the jack collapsed sideways leaving the car on him, breaking his arm. He screamed out to his girl friend, she came outside, saw him under there and went back inside to watch tv. Neighbour got the car off him.
You cant rely on what people might do in an emergency.
Return to “4wd Safety”
