Just scored an awesome price on a Mistral td27 Intercooler+Both intake and exhaust manifolds.
http://www.trademe.co.nz/Browse/Listing ... =607109226
If im not mistaken these should bolt straight up to the D21 TD27t Terrano engine??????
Good TM Score! *UPDATE*
Re: Good TM Score!
yup they sure should
Re: Good TM Score!
Yea, that is a good score! Yea, either just use intercooler and make custom mounts, or use those manifolds which have brackets built in
Re: Good TM Score!
slide wrote:Yea, that is a good score! Yea, either just use intercooler and make custom mounts, or use those manifolds which have brackets built in
I thought I may as well use the manifolds so everything should be bolt on and wont have to do any custom work at all ,apart from a bonnet scoop that is
Re: Good TM Score!
Good score
All bolt on. but you will need to make a tail from the 3 bolt turbo flange to IC. Like this one
Big Horn bonnet scoop with bellows in the exact center,
All done.
Only fits with a 2 inch body lift
All done.
Re: Good TM Score!
Yip. Might be able to get away with 1 inch body lift if not using the fan set up.
Re: Good TM Score!
My mates just fitted the intercooler (custom mounts and pipes) in without bodylift. Yet to do scoop yet. But intercoooler fits under bonnet
Re: Good TM Score!
I have finally got this all installed and it came up great, everything bolted up, and cooler fit without having to do a body lift. Now just to install the scoop and bellows.....
Found this on ebay and was much easier than having one made up here
http://www.ebay.com.au/itm/Turbo-Compre ... 1202338529?
