As title says. As cheap as poss. Anywhere considered. Early model one with 3 bolt flange on outlet.
***URGENT*** WTB Nissan td27 turbo
Re: ***URGENT*** WTB Nissan td27 turbo
how bad is the broken turbo simbian, is it sledge hammer broken or rebuild broken?
http://www.trademe.co.nz/motors/car-par ... 816904.htm
or if ya can get ya hands on the exhaust manifold from a ETI model theres a 4 bolt on TM too.
http://www.trademe.co.nz/motors/car-par ... 568655.htm
Hi Simon Check out T/Me Listing #: 610839728
Broken shaft so not rebuildable
Can get a seized one if need be.
Trying not to have to modify anything as the truck is up north and I have limited resources up there.
Thanks Steve. Shipping will put it up near this one which is local.
http://www.trademe.co.nz/motors/car-parts-accessories/nissan/engines/auction-610512146.htm
I have one if you're still looking.
Thanks for that Cambo. Have bid.
So far in the last couple of weeks, I have got one off a wrecker for $200 and one off TD Power for a measly sum and this one.....hopefully. One replacement and two spares
Cheers for all the eyes out.
You could just by this http://www.trademe.co.nz/motors/car-par ... 974588.htm
It's even a 3 door!!
If you come across the Garrett version (not sure what model it came off) they appear to be a lot nicer design, picked one up for mine awhile ago, straight bolt in except for oil drain, turbo itself is slightly larger, but defiantly has a lot nicer exhaust flow.
I just cut the extended part off the housing where the flange normally is and have modified my turbo - intercooler pipe to fit.
sibainmud wrote: One replacement and two spares![]()
That should keep you going for at least 3 weeks
Yeah...ha ha. TD, aka Steve said, why don't you spend more and get a custom built turbo? When asked how much, $1500-$2000 was the answer. At an average of $100 per standard unit, by my calc's, that pays for 20 turbos. As I'm only up to the fourth in as many years, i think i will stay with standard turbos stressed out on T2. However T3 MAY be a different story.
