where the heck is this computers that controls the outo on there terreno D 21 I cant find it seems there placed in areas not the same on all models
inside the fuel tank maybe
wheres the computer that control the outo on d21 terrno
Re: wheres the computer that control the outo on d21 terrno
Behind the right rear speaker assembly.
ChurchurDan
or left rear they hide all the good stuff in the rear quarters
philip121 wrote:inside the fuel tank maybe
Correct, you will need a gas axe to get it out.
lilpigzuk wrote:philip121 wrote:inside the fuel tank maybe
Easy as to do, drill a hole in the tank to get yourself started, then just lay into it with the aforementioned tool.
X3, and then we'll be a little closer to proving Darwin was right eh... Gwon, ya know ya wanna
philip121 wrote:where the heck is this computers that controls the outo on there terreno D 21 I cant find it seems there placed in areas not the same on all models
This might help you?
http://i195.photobucket.com/albums/z218 ... ea74fa.jpg
http://i195.photobucket.com/albums/z218 ... 2502d6.jpg
Ph 0212078472
Ph 0212078472
thanks pete I found it and give it crc I think last owner drowed this truck
what would a used computer control untit for the outo cost are they all the same
If you are still having issues getting stuck in first you need to replace the rear speed sensor on the trans. It sits on top of the housing between the transfer case and trans you will need to drop the back of the trans to see it/remove it. Cut it out of the loom and solder another one in (get a 2nd hand one from a trans shop). I have replaced ALOT of these at work for this problem.
I see do you work in a garage
like cauld I pay you to do it if it don't stop
When abouts are you?
