Because I'm wanting to adjust torsions at home soon ill need to do a quick wheel alignment until I can get into the shop
Can anyone school me on how to do it?
I was going to to setup two boards and lean against the front wheels and measure the top and bottom in front of the boards and behind the board so all measurements are the same?
Maybe some has a better trick?
On a Holden rodeo IFS
DIY wheel alignment
DIY wheel alignment
- skid
- Tyre Man
Re: DIY wheel alignment
GotFlex wrote:Because I'm wanting to adjust torsions at home soon ill need to do a quick wheel alignment until I can get into the shop
Does it have castor and camber adjustment or just the toe adjustment
- firestonecruiser
they have camber and castor adjustments, all done thru the shim packs
I did it by eye on my terrano till i could get into town to get it done.
Wasnt very hard at all, i used two boards like you have said, measured everything up square, then adjusted to suit.
Wheel alignment guy said it was pretty darn close and only needed some fine adjustments.
Must have fluked it
Must have fluked it
Yeah that's one sweet ill do that
