problem is, my trucks 12v
what can i do here? whats a cheap option if any?
do i need to replace the whole winch motor?
cheers for your help in advance
DaveM wrote:What do you have? I have a Warn 9000lb 12v, need a 24v.....
Dirtydog wrote:Since youd be best running two batterys, would it not be easy to just connect them to both batts in series?
thinking out loud here?
NJV6 wrote:Dirtydog wrote:Since youd be best running two batterys, would it not be easy to just connect them to both batts in series?
Can't see the rest of the vehicle liking 24volt.....![]()
With a bit of fancy wizardry you can do it but you still need the 2nd battery. A mate did it with his winch truck, but blowed if I know how it worked.
Dirtydog wrote:This is more of a question for me,
But if its set up correctly running the truck of a single battery, and only the winch using them both, how would it make the rest of the car run at 24?
