TERRANO PROBLEM
A place where Useful information on makes of 4wd is stored by Tech Authors.
Moderators: Steve_t647, Tech Authors
Weldinc
TERRANO PROBLEM
Post by Weldinc »
After hosing out the inside of the terrano, td21 model, i turned the car off, went to start and nothing, used a volt meter and found with the key on ACC it has full power 12V, and soon as it goes to on the power is 5V, any ideas?
keithal
Re: TERRANO PROBLEM
Post by keithal »
lighter and some petrol
Smurf
Re: TERRANO PROBLEM
Post by Smurf »
keithal wrote:lighter and some petrol
WTF dude, new guy, what a great intro to the site
keithal
Re: TERRANO PROBLEM
Post by keithal »
my sincerest apologies
have you tried jump starting it? or if its manual roll starting it?
Weldinc
Re: TERRANO PROBLEM
Post by Weldinc »
Auto and yes, same problem, battery is fully charged, never had this problem before
Weldinc
Re: TERRANO PROBLEM
Post by Weldinc »
May have to have it towed to and auto electrician as ive given up trying
centralnavara
Re: TERRANO PROBLEM
Post by centralnavara »
Voltage drop when load comes on can be cased by a dirty battery termanals
Take each termanal off the battery and use some good rough sand paper and polish up the termanals and the inside of the termanal clamp where contacts battery post and refit nice and tight
keithal
Re: TERRANO PROBLEM
Post by keithal »
Weldinc wrote:May have to have it towed to and auto electrician as ive given up trying
make sure the transfer case is in neutral when towing or you could damage the auto
callum007
Re: TERRANO PROBLEM
Post by callum007 »
Does sound like dirty contacts or similar. Does it make any clicking sounds at the starter solenoid? Give the starter motor/solenoid a "Tap" with a hammer..
tweake
Re: TERRANO PROBLEM
Post by tweake »
can also be faulty ignition switch contacts.
Weldinc
Re: TERRANO PROBLEM
Post by Weldinc »
Tried jumping it again and it fired up but cuts out, now the batt is completley dead, thinking maybe alternator or battery is faulty, sitting in the shed with the dehumidifier going inside it while battery is on charge, will keep posted, thanks heaps for the help i did notice the ignition was binding with the key in it so sprayed crc in the lock and its fine now
snatch22
Re: TERRANO PROBLEM
Post by snatch22 »
Weldinc wrote:After hosing out the inside of the terrano, td21 model, i turned the car off, went to start and nothing, used a volt meter and found with the key on ACC it has full power 12V, and soon as it goes to on the power is 5V, any ideas?
hi don't they have a computer under the seat?
Weldinc
Re: TERRANO PROBLEM
Post by Weldinc »
nope mine doesnt, i think the petrol v6 one does
kiwipete
Re: TERRANO PROBLEM
Post by kiwipete »
Why did you hose out the inside?
I suspect you have water in the ignition switch and this is causing a short or voltage leakage and this is your issue.
Disconnect the battery and spray the ignition switch clean with a good electrical contact spray, not WD40 or the likes. You may have to take the steering column covering off to expose the switch properly. Only reconnect the battery when it is properly dry inside.
Ph 0212078472
Weldinc
Re: TERRANO PROBLEM
Post by Weldinc »
Used the hose to wash the mud away, i didnt spray it with the nozzle, i took the nozzle off and just let it run, i made drain holes for the water to run off
Weldinc
Re: TERRANO PROBLEM
Post by Weldinc »
I have done this a million times and just now its had a problem
Return to “Tech Section/Library”
