pitman arm needed
pitman arm needed
im looking for a pitman arm for my 6.5 inch lift the guys will not cert it with a usa pitman arm he will only cert it if its from au can anyone help me i need a au made pitman arm
Re: pitman arm needed
whats the au brand
lost me on the au ....why wont they cert the yank one ....get one made up or in from aussie ..
v8 tj...luvs the gas......
the cert guy is a wanker im where did you get the cert from for your xj in photo
Cert guy should know that US does have RHD Jeeps (they are used for US Postal Service). Unless you told him the arm was for LHD
For example: http://www.quadratec.com/products/56110_0010.htm
dose it mater if you have a left hand or right hand one ?
its for a jeep cherokee
4x4part wrote:dose it mater if you have a left hand or right hand one ?its for a jeep cherokee
gotta be right hand drive one I think...same as when I was trying to sort panhard rod on tj , got one made up in the end... my xj was only on 3 inch lift didn't need aftermarket pitman arm.. try that link I gave to wooders garage in aussie .... got my cert down here in grand theft auto land (ch ch )...got pics of ya set up....
Williams 4x4 just done some work on it in the north island i have just moved to oamaru try to get truck certed so i can drive down as soon as i can il get some pics up that pitman arm is the only thing he siad he wouldnt pass
i might see if the factory one will work for the cert them after put the other one back on it should work because the steering is all after market this link is the one i put on http://www.ironrockoffroad.com/Merchant ... y_Code=PFX
you might have to bite the bullet and get one of these in ...tis what you need .........
factory one wont work on your size lift and has to be rhd drive ,, that's why cert man saying no ...
http://www.wooders.com.au/index.php?mai ... s_id=12796
cheap enough ......
cheap enough ......
