Toyota Free wheeling hub - spring wanted
Selling or wanted vehicles.
Danjr
Post by Danjr »
After the spring for a Toyota/Asin free wheeling hub. Mine has snapped. Or a whole hub if not too $$$.
Dan
2MEKE
Re: Toyota Free wheeling hub - spring wanted
Post by 2MEKE »
If this is the one you're after, I rolled one from a piece of 2.4mm tig rod....hasn't let go yet.
oldblue
Post by oldblue »
Is tig filler rod made from spring steel?
2MEKE
Post by 2MEKE »
oldblue wrote:Is tig filler rod made from spring steel?
No it's not but mines been like that for over 2 years without issue.
It's only holding the the clutch and follower together and is threaded into both parts. I rolled mine slightly larger than required and it's works fine.
Total investment was 10mins of my time and maybe 20 cents worth of rod...IMHO it beats paying $40
oldblue
Post by oldblue »
I need to make 3 of these ( when I have done an exchange of hubs ) the exchanged hubs have streached springs . Can you remember what size pipe did you use to wrap the rod around and was it done hot or cold?
2MEKE
Post by 2MEKE »
It was rolled cold in slip rollers at work so no pipe size to reference off.
I just rolled it down to slightly larger than the original. .
Danjr
Post by Danjr »
Awesome idea. Cheers for the reply! Saved me some cash
