re-grooving simex
re-grooving simex
Hi all I've just brought some second hand 33 inch simex jungle trekkers and they have minimal tread in the center i was wondering what the likelihood of grooving them out to add a little to the center was? (off road use only)
How far could they be grooved into the casings without compromising to much... some one online said an inch so id be happy with 12mm-10mm ?
Any one done this before even with any tire that can give advice ?
Cheers Pete
Cheers Pete
Re: re-grooving simex
1 inch = 25.4 mm
I don't know the answer to your other life's mystery. But it does seem like the previous owner ran incorrect tyre pressure for that kind of wear.
sorry i meant to say id be happy with 12 mm let alone an inch
I took about 10 mm out of a set of creppies that were bald in the center think there is heeps left too
did you hit any cords? id be happy with 10mm
na didn't hit anything they even bag now
what kind of Grover did you use and did you get them rebalance after the Groving?
You're worried about balancing? With Simexes? =
not really but had to ask the question...
angle grinder - works but a lot of smoke & hot sticky rubber.
Chain saw - easy and works but arm gets a bit tired.
Tyre groover - the one i used was worth a couple of hundie, only had a 1cm groove width - still a lot of work.
Grooving 16inch 285/80 continential ag tyres - heaps of layers tho - hit wires a couple of times but had no problems- do a heap of bush bashing with no probs. and they are free!!
^^ Is than an MK/MQ Patrol front axle??
Daihatsu Rugger, they have Dana style diffs.
poss682 wrote:what kind of Grover did you use and did you get them rebalance after the Groving?
used a electric tyre grove iron cuts 10mm wide by 10mm deep easy to use takes about 10 mins a tyre
