spigot bearing
- mud_slinger
spigot bearing
does anyone no how to get a spigot bearin out? tryin to get mine out but dont wana move either way
;-p
internal bearing puller legs on a slide hammer
or pull the flywheel off and drift it out(recomended) remembering to put loctite on the bolts when re-assembling also skim the flywheel while its out
Try Hydralicing it out, fill the back of the crank with grease and drive in a suitibly tight fitting object to force it out.
Try a makeshift slide hammer, grind a notch in a rod that just fits through the bearing, weld a stop on the other end and put a weight on the rod. Fit it to the bearing and wedge it with a screwdriver then slide the weight firmly down the rod
J Top
J Top
- mud_slinger
- Moriarty
If the bearing is in the main shaft, use the hydraulic method. if you dont have a siutable punch that is a sliding fit in the bearing, use something slightly smaller.
You got kids? steal the ballbearings out of the pushbike hub (or buy some, cheaper than having kids...) and sustitute the balls for grease. Insert nearly fitting shaft and whack with large club shaped device. HARD!!
Nearly forgot (getting old...) use SMALL bearings, smaller in dia then the walll thickness of the bearing. Why? Cos as you whack the drift punch (shaft) the balls will displace in the bearing and push the bearing up. If the balls are bigger in dia than the wall thickness of the bearing, they wont go pass the drift punch.
- mud_slinger
- mud_slinger
- mud_slinger
- mud_slinger
You should be able to find an electric dremel at a hardware store like bunnings, mitre ten etc. They also do air tools from time to time, but then you would have to have a compressor etc. From memory price is around the $100-$150 mark. Good general tool to have in your arsenal. Getting the cutting wheels can be a bit of a trick, but if you get stumped at the hardware store then you can try an air tool specialist or let your fingers do the walking etc etc . Where abouts are you?
- mud_slinger
On trade me here. Also called die grinders, which is probably the correct term.
http://www.trademe.co.nz/Home-living/To ... 237433.htm
- mud_slinger
