LJ71 alternative radiator
bryandc3
Post by bryandc3 »
Hi fellas,
I am after a new radiator for my landcruiser (manual LJ71) I have been quoted over $450 for one.... :shock: :shock: :shock: :shock:
So my question is has anyone else replaced theirs and found the same problem, so put an alternative radiator in and if so what did you use? Cheers guys
kbushnz
Re: LJ71 alternative radiator
Post by kbushnz »
That's cheap. I did one in my lwb a few years back and cost near on twice that.
Crash bandicoot
Post by Crash bandicoot »
What so special about them...gold plated?
nissan boys use ford falcon coolers and fans
as for the prado/crusier
same getup as the 97- 05 hilux/ surf there are a couple on TM at the mo from $99 to $350.
anything more then that i'd start thinking about an all alloy aftermarket job.
slide
Post by slide »
Hi there. I've got a lj71 (auto) radiator for sale.
Not sure on freight nelson-hamilton, but ORE courier may be able to help?
$200 and its yours.
PM me if you're keen
Nath
bryandc3
Post by bryandc3 »
Crash bandicoot wrote:What so special about them...gold plated?
I have had a good look on trademe but cant seem to find one thats the same, closest I can find is
http://www.trademe.co.nz/motors/car-par ... 614985.htm
but the bottom inlet is on the wrong side.
slide wrote:slide
Post subject: Re: LJ71 alternative radiator Reply with quote
$200 and its yours.
Nath
Thanks mate, yours must be the one on trademe, if I cant find a suitable new radiator I will take you up on that.
d_b
Post by d_b »
I've got one from an auto lj78 pm if your interested. south auck
Smurf
Post by Smurf »
I recently got my LJ radiator recored, at around $600.
Can't get new replacement off the shelf. KZJ ones are different, and the Surf ones as you have found out have the outlets on the wrong sides, I think the dimensions are wrong also.
bryandc3
Post by bryandc3 »
Thanks for all the feedback guys, decided to bite the bullet and get a new one from the radiator shop $520 all up..
Smurf
Post by Smurf »
bryandc3 wrote:Thanks for all the feedback guys, decided to bite the bullet and get a new one from the radiator shop $520 all up..
Good price, Which shop?
bryandc3
Post by bryandc3 »
https://plus.google.com/101823285804837 ... l=nz&hl=en
Good bunch of guys and were quite helpful
