suzuki v6 dieing problem
For all Suzuki related topics
peanut.901
Post by peanut.901 »
anyone no why my v6 Suzuki dies every time you stop
every-time you drive apart from when its cold you put your foot on the clcuth to stop and it dies you start it up and if you don't pump accelerator it dies
anyone no whats wrong anything would be a help cheers
Weemsy
Re: suzuki v6 dieing problem
Post by Weemsy »
i had this with my v6.
i found the plug were rusting & there was moisture in the plug caps (spark plugs)
blow out the plug caps & replaced the plugs fixed it.
probably a place to start & it wont cost a fortune
good luck
ladeda
Post by ladeda »
Try cleaning throttle body
peanut.901
just blew out spark plugs etc didnt fix
Chairmen
Post by Chairmen »
I have the same problem with my V6.. I was going to try turn the idle up?
Possibly clean the MAF sensor.. I'm stumped with mine it's almost like there's a vacuum leak somewhere why it dose it...
For me it happened's a lot after revving the engine up
So annoying!
Return to “Suzuki”
