Did the XJ tow package ever make it to NZ shores?
Jeeper
Post by Jeeper »
wanting to ID my HPD30 gears and am 99% it will be 3.55 but the other option is 3.73 if it came from a vehicle with the tow package. I don't know anything about the original vehicle other than its non disco and has 94 XJ written in white marker on the diff case by the seller (no ID tag anymore either).
XJCrawler
Re: Did the XJ tow package ever make it to NZ shores?
Post by XJCrawler »
i assume you don't have the other vehicle to check the rear diff tag? - might have to check it marking a couple lines with some chalk and turning a hub/wheel?
TJ
Post by TJ »
Or you could count number of teeth on the gears
Jeeper
Post by Jeeper »
Cool sorted 3.55 cheers all
Return to “Jeep”
